Larry Surface Finally Releases Ohio Bigfoot Footage On YouTube
Post by admin » Sun Nov 10, 2019 12:30 am
The video was removed from YouTube, as Larry met quite a bit of resistance about it. I am posting the screen capture that appeared on Bigfoot Evidence for discussion and comments.
Bigfoot Evidence wrote:
larry surface bigfoot.jpg (5.39 KiB) Viewed 4922 times
In November 2011, Ohio Bigfoot researcher Larry Surface decided to mount a camcorder behind a night vision scope after months of investigating Bigfoot activity at an elderly couple's property in southern Ohio. On one lucky night, under full moonlight, Larry's camera captured a 7ft tall light-colored hair subject meandering around the property. Not only did Larry get video evidence, the "Bigfoot" also left hair samples which was later sent to Dr. Melba Ketchum for DNA testing.
Larry wrote the following on his blog:
The subject was seven feet tall which can be proven by analysis. This was at a secluded residence, and there is no modern Human person that tall within many miles of this location. A light tan hair and a white hair was found on a hair trap nearby, which microscopic analysis showed to be identical to other known Sasquatch hair. The subject was covered in light colored hair, including the brow and across the mid face. The skin appeared to be dark gray or black, although color of skin and hair is hard to determine in the green night vision.
Larry Surface has kept the video private, only playable on his blog. In the past, he has asked bloggers to remove screenshots of the figure.
Return to “Video Evidence”
